Help dropping image as billboard in iclone 5
https://forum.reallusion.com/Topic261262.aspx
Print Topic | Close Window
By Resoundproductions - 10 Years Ago
Hi,
I'm trying to drop images into a scene as billboards.  I know I'm supposed to right-click drag the item then select 'billboard' from the pop up menu.  Problem is I only get the pop up menu about 5% of the time.  The rest of the time it just applies it as the sky or what not.  Pretty sure its a bug,
Does anyone know of an alternative way to import an image as a billboard?
Any help is greatly appreciated!
Also, ctrl clicking to import as a plane works fine.  Anyone know if there is a way to change the plane to a billboard.
By Peter (RL) - 10 Years Ago
To be honest it sounds as though there may be a problem with your mouse.
Right clicking and dragging should work 100% of the time and does for me when I test it. If your image is appearing as a background then that is what you get if you left click and drag. It may be the buttons on your mouse are not be working efficiently.
Right click is working fine on everything else but then again, I am running a mac mini with a windows partition and I'm using a magic mouse so could be worth trying another mouse.
Cheers for the advice!
By Kelleytoons - 10 Years Ago
Peter,
Just for info sake, I have exactly the same problem with Windows here in iClone 6.  I was watching a tutorial and saw it showed how to drag an image in as a billboard (or to get that option) and I couldn't get it to work even one time (it always just made it the background image).
Win 8.1, and two wireless Logitech mice on two different computers (so I suspect it's a bug as well).  I ended up just creating the billboard from the menu and populating it by dragging the image onto it.
By Cricky - 10 Years Ago
I just verified this still works,  as I haven't used the option in some time now.  Windows7 Ultimate, if that matters.
And I just tried it now and for the first time it actually worked for me (the other day I could not get it to work no matter what).
So... I don't know (intermittent issues are the pits).
By animagic - 10 Years Ago
I always do those things the long-winded way, so I tried it and it worked. Right-clicking dragging and dropping brings up the menu. I have Windows 7 Pro.
By lamar.mack - 10 Years Ago
Novice here!  I was able to just drag and drop images and video into a project.  All of a sudden it just stopped working.  I have reinstalled the software I4, I am sure it is user error what happened?:
By justaviking - 10 Years Ago
lamar.mack (11/22/2015)
Drag-and-drop using the RIGHT mouse button?
Tried that, the image copy and moves but will not paste I get a zero with a slash sign.  Thanks
Just want to make sure I am using the correct term.  It is the drag and drop function that stopped working.  It as easy before I could drag from my windows folders.
