Putting this under the General iClone area leaves a few questions.
Depending on the version of iClone you are using, this can be fixed easily, and in iClone 6, the coat can be converted to Soft Cloth to Flow if desired.
It also depends on the output you created from DAZ
The questions are: What versions of both are you using?
I also do LIVE training sessions through Skype... there is a co$t involved. When finished you will have the completed model on your system ready to go. You have a choice to not use the service of course. Contact me by P.M. if interested.
toonarama (10/21/2015)
Having previously purchased the Toon Gramps Mad Scientist from Daz3d and converted it I know that it is a great character but his long and tight coat means that unless you do a lot of amendments to your motions his legs will continue to peek through his coat. So although it is advertised as accepting all iclone motions this might be stretching the truth a bit. Perhaps when it has been converted this has been fixed but on the product page for the Grimm Skeleton (also from 3duniverse) the same issue exists.
Hopefully there is a way of solving this (apart from tying his legs together) but just bear this in mind if you are thinking of purchasing.
