Facegen and Iclone
https://forum.reallusion.com/Topic25757.aspx
Print Topic | Close Window
By toonarama - 17 Years Ago
Hello there
I've seen a few posts saying it is possible to load facegen images as faces.
I have managed to do this by
FACEGEN
Saving Image as BMP (ie not exporting)
ICLONE
Loading face by using Create Face/Load Image
Can I ask whether this is the best method to use or not
thanks for any help
all the best
Mick
By Sen - 17 Years Ago
Hello
yes it's possible . take a look at this thread .
some faces come to "facegen modeller" .
save image in facegen , load image in Iclone and adjust the face .
An another way is propably possible .
many thanks
Ill give it a go
By Ulaw - 10 Years Ago
Greetings everyone, please I want to know if it is possible to import chuck into Daz studio then morph the face into mine and export it back into iclone, and how do I go about it?  thank you for your help.
By animagic - 10 Years Ago
Ulaw (3/20/2016)
This is an old thread for iClone 4. I assume you are using iClone 6?
Anyway, what you are suggesting is not possible. In the case of Chuck, you can create a face using the built-in face mapper in iClone. For the newer iClone 6 characters, the head creation is now outside iClone. Currently you need CrazyTalk 8 Pipeline, which allows you to create a 3D head from a photo and then export it for use in iClone and Character Creator. This new Head Creator will also be available as a separate program and will then presumably be cheaper than CT 8 Pipeline.
