Import PDF as image for animation?
https://forum.reallusion.com/Topic256094.aspx
Print Topic | Close Window
By ireallusion - 11 Years Ago
Hye, i've been playing around with CT7, but apparently CT doesn't allow me to import pdf images in order to animate them?
Drag&dropping a .png is no problem.
About all of my images are in pdf, in order to reduce pixelation.
So it would be really great if CT can/could import PDF's...
Thanks for helping me out...
By AverageJoe - 11 Years Ago
PDF isn't really known as an image format per se, and as such providing support for PDF as an image would be odd, especially in a niche application such as this.  I'm sure they may consider it, but there are plenty of actual image formats that also reduce pixelation, especially if it's not a lossy compression format. I'd rather the developer spend there time on features that the majority of people would use, and I don't believe PDF as an image is high on the list of commonly used formats for images.
well, yes... but it exists anyway and is a very handy format when one wants to compress without any visible quality loss or pixelation...
I'm sure it's wouldn't take many sleepless nights of coding in order to support pdfs...
I edited this response because it sounded too negative... I don;t agree with PDF support, but there's no reason why you can't suggest it...
By Peter (RL) - 11 Years Ago
ireallusion (10/1/2015)
We will certainly make note of your request, but as PDF is not really considered a standard format for images it is unlikely to be supported in the near future.
We do appreciate the feedback though. :)
