Character Model malformed
https://forum.reallusion.com/Topic255180.aspx
Print Topic | Close Window
By Brennon - 11 Years Ago
Hi all,
When I bring my model from CC into Exchange, all is fine and animations are good. When I export as FBX for Unity, the model comes into Unity and it is deformed - the eyes are pushed out of the socket, the skin around the face and jaw is torn and generally it is a mess.
Any help on how to fix this would be great - and also any pointers on if it is possible to make the model as higher resolution as it is in CC would be great. We only want/need the head in the scene with no backgrounds etc in Unity, so performance should not be an issue.
Really appreciate the help.
Cheers
https://forum.reallusion.com/uploads/images/6f33fb61-0073-4eee-af42-01cc.png
Sorry, thought adding the picture might help explain it.
Cheers
By vidi - 11 Years Ago
Looks not deformed , but inverse normals
Try in the model Tab from the inspector calculate normals .
I have not CC for testing so it is only a thought.
Thanks Vidi for that response. It was a good suggestion, but after trying quite a few variations in the model tab, it is still the case. The fingers on the model are also showing it also.
Killing me.
Cheers
Ok try this
select the materials and change the rendering mode to cutout
see tip 3
https://forum.reallusion.com/254937/CC-Tips-for-Unity?Keywords=unity
I think now it should work. It is not deformend, only transparent
What a genius you are!!
I found that only materials set to rendering mode of Transparent, changed to cut out as you suggested, fixed it entirely! I will try and find if that is a material setting in 3DXExchange.
Thank you Vidi for taking the time to consider this issue for me and to keep suggesting fixes.
Flowers, chocolate for you!
Cheers
Nice to hear it works :)
Thank you for your nice response :kiss:
