By ajm5050 - 10 Years Ago
I've purchased the Character Creator Essential bundle, but I can't seem to install it. Whenever I start the Installcontent.rld, I get a message that says;
"RLDownloaderR2.exe - Entry Point Not Found" The procedure entry point?registerConverterFunction@QMetaType@@SA_NPBUAbstractConverterFunction@QtPrivate@@HH@Z could not be located in the dynamic link library Qt5Core.dll
Can someone help me resolve this issue. Thank you.
Based on the zero replies to this thread, I think it's safe to assume that this is a rare occurrence. However, Reallusion was able to fix this problem for me, so I'll share how just in case someone else experiences the same issue.
Reallusion basically instructed me to delete the folder "C:\Program Files (x86)\Common Files\Reallusion\Downloader" and to download a new or perhaps I was just re-installing the same version, not sure, but they've provided me a link to the downloader and I was instructed to install that program.
After I followed the instruction, the installation worked flawlessly! I don't know if I'm allowed to share the downloader program, so I won't be sharing that link with you, but just contact Reallusion if you encounter this problem and ask them for the v210 downloader.
That's it. Have fun with CC, I know I will.
By Peter (RL) - 10 Years Ago
Glad to hear you have everything working now. :)
The new version of the downloader is available for everyone via LiveUpdate. If anyone is having similar problems, please go to Start > All Programs > Reallusion to run LiveUpdate.
By IO1 - 10 Years Ago
Thanks ajm5050 you've saved me a ton of time.
By Famestar - 9 Years Ago
man findet das Tool einzeln in der Order History unter b) If you only own iClone 5, after confirming the program compatibility, you may download and setup the Conten Downloader Programm to install the new format installer (Universal Installer).
vorher wie oben beschrieben den alten Ordner löschen oder umbennen
vertrug sich eventuell nicht mit der UT-Engine, die wurde zumindest bevor der Fehler kam installiert
By loliaudio - 8 Years Ago
Thanks for the post. Same happend to me. I erased the Downloader folder and re-installed it with the latest version. Everything working fine now...
