Tutorial on how to improve performance in Adobe Premiere.
https://forum.reallusion.com/Topic253321.aspx
Print Topic | Close Window
By Dragonskunk - 11 Years Ago
https://forum.reallusion.com/uploads/images/0d654801-c277-4486-a976-f401.png
Want to use your powerful graphics card to edit videos you made with iClone by editing it with Adobe Premiere?
But when you go to Project>Project Settings>General the Renderer selection grayed out?
Then this article may be for you.
My GTX 780 Ti GPU is not allowed to be used for graphics accelerated editing.
But I was able to add it to the allowable list and use my GPU. Here is how anyone can do it.
1) In the Adobe Premiere folder where the .exe is do a search for
cuda_supported_cards.txt
2) Open it in notepad and add a line with the name of your card as written in your system information in your Nvidia control panel. Then save.
3) If you save and it says access denied download this: TakeOwnership.zip Adding this will include on the right click list a Take Ownership option. Then you can right click on the folder that the cuda_supported_cards.txt is located and choose Take Ownership then you will not longer get an 'access denied' message for any folder you apply Take Ownership.
4) In your Nvidia control panel under "Manage 3D Settings" If Adobe Premiere is not added to the list of programs to customize then add it.
5) In the Specify setting find "multi-display/mixed-GPU acceleration" switch from "multiple display performance mode" to "compatibilty performance mode"
6) When you go to Project>Project Settings> Now you can use your graphics card.
By james_muia - 11 Years Ago
Good post. I had to do this same thing a while back for both my upgrades to a GTX 770 and GTX 970.
Although, I only had to add each of my Nvidia cards to the text file - once I do that, and re open premiere, it auto detects the card.
By animagic - 11 Years Ago
I don't use Premiere, but a good tip; thanks for posting. "Allowable" graphics cards, that's a new one for one...:unsure: Weird also, because the 780Ti is a pretty powerful card...:crazy:
animagic (9/24/2015)
Nvidia, is in bed with Adobe and Autodesk to make sure that you pay top $ to buy specific cards. Quadro cards for Autodesk for instance, anything else the performance is intentionally knee capped. For rotating a prop while editing the GPU gets utilized but playing back an animation the GPU lays dormant unless you got a specific card. Might as well use on board graphics as to use a gaming card to animate with Autodesk.
And the only way to get a gaming card to work with Autodesk is to fool the Nvidia drivers that your card is a Quadro by soldering wires on you card but what a leap of faith to hope that will work.
