How to Add more pose in Calibrate : iClone Character Creator
https://forum.reallusion.com/Topic251208.aspx
Print Topic | Close Window
By Sen - 11 Years Ago
Hello ,
You need more pose  in calibrate tool :
- make sure your imotion is a pose
- drag and drop or copy/paste your imotion in
- rename it : example here rename to 10.10 and 11.11
- open .ini
- and add :
Restart iclone character creator for best result :
By Peter (RL) - 11 Years Ago
That was quick Sen. ;)
I knew you would be the first to start tinkering. :)
By JIX - 11 Years Ago
Way cool ... the first unofficial mod is there before the official release of the CC. :D
I hope you don´t get me wrong, Peter! I´m only joking for sure ...
Thank. More to come 😀
By Lord Ashes - 11 Years Ago
1. Is RL employing Taiwanese programmers? If I am not mistaken those are Traditional Chinese characters in the file or is this a form of encryption (i.e. shifting ASCII character to UNICODE to make them unreadable)?
2. Sen, great work. Now all you have to do is crack how to make/add custom CC bases and how to make/add custom CC morphs. Bonus points if you do it before CC PIPELINE comes out ;-)
What do you mean by Custom cc base ?
Sen (9/4/2015)
I mean that CC comes with a shirt (dress style), pants (jeans) and dress along with some other few things like underwear and accessories.
There is no skirt base, there is no coat base. There are a lot of empty categories in CC unless you buy the CC Essentials Bundle.
I managed to make a fairly convincing leather coat from the shirt base but the bunched up sleeves of the shirt make it hard to use that base as a winter coat (because the sleeves will be too short).
What I liked about iClone prior to CC was you could buy the different cloths (like G5 Cloth) to save time or (with 3DXchange) you could create them yourself to save money.
With CC the bases are CCCloth files which neither 3DXchange not iClone can generate. Yes, you can take a CC Base in iClone modify the materials, opacity and so on and save it as a CCCloth file but as far as I can tell, I can't create a CCCloth file (to use with CC) from scratch (or mesh modifications of an existing CC Base). Even modifications to CCCloth meshes are not allowed (i.e. I can export Heidi's dress, modify the mesh and re-import it but you cannot do the same with CC characters - the mesh can be modified in 3DXchange but when you load the result in iClone it uses the unmodified mesh).
I know...I know...some is going to respond to this and say "just buy the CC Essentials Bundle and stop complaining". Well the CC Essentials Bundle adds a lot of bases but there will always be something that some content developer wants to create that is not going to be covered by one of the CC Essentials bases. This is why the "CC Pipeline" is coming, right? But what about now? Any way to either mesh modify the existing bases or make some from scratch?
