Switch to System Memory to optimize performance
https://forum.reallusion.com/Topic251106.aspx
Print Topic | Close Window
By Realtimer (RL) - 11 Years Ago
-- Switch between system memory and graphics card memory to optimize performance --
If you are running a video card with less than 2 gigabyte of independent video memory, then it is recommended to have the program use the system memory instead.
To use system memory, go to the Character Creator's  Edit Menu > Preference. Once inside the preference window, scroll to the bottom, and un-check the “Maximize video memory usage” option.
In addition, if you have sufficient system memory (>8GB), then you may try to load several substances at one time by editing multiple outfits without reloading. Do this by unchecking “Load one Substance a time” option
Then, restart the program for the settings to take effect
https://forum.reallusion.com/uploads/images/fe51515d-bc2c-498d-bf46-69cf.jpg
