By TrueInventor - 11 Years Ago
Hello! I have 8gb ram, 4 core cpu, and HD7770 videocard. So a decent hardware. BUT, Iclone 6 runs with extremely low fps (1-5). Even it's low when nothing is imported just the grids are visible and trying to rotate the view. I had a windows 8.1, now I have win10 with dx12. The problem still exists. What should I do to fix this?
By wires - 11 Years Ago
You have posted your question in the iClone 6.03 forum, have you downloaded and installed the latest version - 6.11 - of iClone?
Did you have these problems while using Win 8.1?
The problem with the low FPS may be caused by your GPU having only 2 GB RAM and/or a problem with the GPU driver version that you are using with Win 10.
DirectX 12 has nothing to do with solving the problem, your card - and iClone 6, only support DirectX11.
Yes same problem with 8.1. This happened after reinstalling. The first time it was ok. But I reinstalled my windows and then started the error.
I have a solution (It's weird but it's working): At the top right corner in the bar I deselected rigidbody and soft cloth simulation. Then if I turn it back it's working with 60 FPS...
