fbx import
https://forum.reallusion.com/Topic244871.aspx
Print Topic | Close Window
By evidanse - 11 Years Ago
Hi !
I exported gwynn in fbx format via 3dx change and I wanted to modify it in 3dsmax. but when i want to re-import via 3ds change( in fbx format), I can see all the polygons.
I used the fbx export options smoothing groups .
Has anyone the solutions to have a smooth mesh ?
Thx
By GOETZIWOOD STUDIOS - 11 Years Ago
evidanse (7/23/2015)
Hi !
Thx
In 3DXchange you can also "Auto Smooth" your surfaces (per Material).
Select a Material in the "Material (Y)" section, then in the "Normal (O)" set the angle for auto smoothing and click "Auto Smooth". You have to do it for every Materials though.
By Rampa - 11 Years Ago
You can shift select everything you need smoothed in the scene-tree, and then hit autosmooth. Might as well do them all at once.
rampa (7/24/2015)
Ah, thanks for the tip!
Thank you for everything ! I-m saved ! ;)
