By CaseClosed - 9 Years Ago
I am trying to light the scene inside a car. The problem? I can not turn shadows off in the Indigo Render. What I have tried: Turn shadows off on every object in the scene. FAIL Turn shadows off on every light in the scene. FAIL Turn atmosphere ambient light to white. FAIL Turn ambient levels for every object in the scene to white. FAIL
In each case, and all possible combinations of the above, the objects all receive shadows and cast shadows. Please help!! Is there a bug I do not know about? Thank you!
By justaviking - 9 Years Ago
This might be a limitation in the "RT" version of Indigo that we have. I know we cannot have invisible objects that case shadows, but the full version of Indigo can. I'll try and check on that for you.
Meanwhile, could you post a couple of pictures to aid the conversation?
UPDATE: This is the Indigo product comparision page I was thinking of. I don't see any mention of "no shadows" on that page.
UPDATE 2: Here is a forum post by someone who lost his shadows by accident. Maybe you can leverage some of what he did.
I can't post a picture of the render unfortunately. The project is in development and under wraps. Trust my description. Imagine the camera in the back seat, looking at the dash display and the driver. Two directional lights are coming from 2 different directions. This means every part of the car is casting shadows into the interior, and every part of the interior is casting a shadow. It's like the driver is hiding in the dark, with pieces of light hitting his face and hands. It looks really cool, but it's not right for the scene. LOL.
Thanks for checking on that for me.
I tried a point light inside the car, and it's not really lighting the way I would predict. I'm going to try putting point lights outside the car and see what I can come up with. I will let you know.
Thank you!
By andy.cmh - 9 Years Ago
I can't shadow off too. you can goto this post.. https://forum.reallusion.com/FindPost243807.aspx
By Cricky - 9 Years Ago
You can use the surface under the objects to emit a light, and the shadow disappears. It works, just take a few shot tests to get the surface color you like. Increase the emission depending on how much you want to light up the surface.
Found as an option on the Indigo Renderer site.
bbvb17 (7/20/2015) I am trying to light the scene inside a car. The problem? I can not turn shadows off in the Indigo Render. What I have tried: Turn shadows off on every object in the scene. FAIL Turn shadows off on every light in the scene. FAIL Turn atmosphere ambient light to white. FAIL Turn ambient levels for every object in the scene to white. FAIL
It looks like it's an Indigo Renderer issue. Apparently unbiased renderers, of which Indigo is one, can not turn shadows off, for any light. So even point lights cast shadows. Apparently, you can not hide point lights either, so it's like a real movie set... your lights need to be arranged so they are not seen by the camera.
This makes setting up iClone scenes and animations much more challenging than expected if you want to render with the Indigo Renderer.
Cricky, is the surface editing for emitting light, that you referred to, in Indigo RT or in iClone? Could you direct me to the menus? Thank you so much.
I can't get point lights to render properly with the Indigo Renderer. They don't seem to cast much light if any, or if I turn up the multiplier, they create a massive anomaly of white specks across the entire image.
It's also frustrating that with no lights on, the Ambient Light under atmosphere has no effect on the scene with Indigo Renderer, even if the Ambient Color is set to white. Arghhhh! LOL Help!
Cricky, please disregard the questions about the menus. Sorry. I looked more closely at your images. Thank you! I will play with that now.
Yea, I couldn't get the emit light to work on the avatar, and I couldn't get it to work on an object that has a texture map.
Unless justaviking has an answer, then we are going to have to resort to the iClone renderer. It will save us so much render time in the long run!
