If you have Crazytalk 5 and iClone3 then you can create a script in Crazytalk that contains the lipsync vocals and facial animation. Once the the script is saved as a CTS file it can then be opened in iClone3 and applied to any character.if you have Crazytalk 6 then this is not compatible with iClone3 and will require iClone4 to achieve the same functionality. It is worth noting also that iClone4 will have advanced facial puppeteering animation built in which will enable detailed facial animation to be created directly within iClone itself rather than via Crazytalk.
