By samusam - 11 Years Ago
Hi, i exported my person with crazy talk for unity. In the html file there is the audio, but when i import in unity and i copy from tutorial i don't have the audio. Why?
i would know if one export of interactive is one animation for unity. namely if i can to have more animation and associated audio with one export of interactive.
By vidi - 11 Years Ago
if the Model is create already in Unity, here is my workaround for additional CT scripts that I want to use with my Model in Unity.
CT 7 > I create a new Folder for every new export and then I only rename the generated script file in this folder I drag only this script file in my Unity asset folder..
Unity > I use the CT Plugin with my selected Model from Hierachy Tab and drag this scrip file in the load Motion Tab . CT extract now the animation and the Sound file separately to the CT Ressource folder in the asset folder Tab
Now can I use these files for my own programming I not use the CT Api for scripting.
Ok thanks, your method is very correct. But I don't know because the export with the audio imported with crazy talk, unity don't speak. Maybe a my error in the work. Tips?
Ok, with mp3 audio it work!
