By Brazilian Storm - 9 Years Ago
Does anyone have the link of the tutorial that corresponds to this function that only exists in the pipeline.
http://coment.me/-ebRhUP
Thank you!
By jlittle - 9 Years Ago
That function allows you to use a template (for Flash or DrawPlus) to create a single swf file that can be imported into CTA in one step rather than importing each body part individually. Ibis has several videos and comment posted for using the flash template. Do a forum search on Ibis & Template and you should get a few related posts. RL has a tut on the flash template here: https://youtu.be/6O1gcLUbeuY?list=PLNV5zSFadPdmE_qSPdOuQLkOFrfgVIGAf
Jeff
By momillis - 9 Years Ago
The tutorials jlittle linked to (above) are great.
You can find the white papers and other things in the DEV Center here...
http://developer.reallusion.com/docs_cta.aspx
...if you haven't already.
Thanks Momillis!! Know your place in heaven is already saved!
Thanks Jeff!! I'll see your tutorials too! Has already guaranteed his place in heaven too! >
