How can I create a sit on car seat animation with iClone?
https://forum.reallusion.com/Topic236295.aspx
Print Topic | Close Window
By KSAM - 11 Years Ago
Hi guys, I need to know how can I create a sit on car seat animation with iClone? any advise? thanks
By Cricky - 11 Years Ago
A little more detail might help answer this .  What Kind of car (convertible?), what Avatar, etc.  To sit a person down is easy, it's the getting them to the chair (seat) first.  To sit down any character where they stand, use motion layer edit, Letter "W" for the Gizmo, and pull down on the pelvis.  The rest will require more info.
Thanks for help. I want to create something like GTA! get in car and then get out of car. but I can't make it looks like good! the result looks artifact
KSAM (5/17/2015)
See if this works for you.  The download link is in the text portion of the Video.  https://www.youtube.com/watch?v=8tORPEvC4KU&feature=youtu.be&hd=1
P.S.  I tried the AML inside iClone6 and it works to also get the driver out.
Steps:  Choose the Driver, then choose the Jeep, then right click on the Jeep and select "Operate" "Driver Get Off" and the driver will exit, get down, get out, or whatever the vernacular is where you come from..
The Jeep can be set to invisible and still use it's commands as long as the replacement vehicle is aligned "roughly to it's root node.
You can also transfer the AML to a vehicle with the same nodes, but that is for another time.. Oh wait, that was covered about 4 or 5 years ago.. Try doing a search in the forum dungeons for a topic including Jeep AML and replacing it with another car so you can use the old code.
