RDL content Error "Content downloader" Failed to connect to the internet
Home
Archive
iClone 6 Forum
Technical Issues
https://forum.reallusion.com/Topic232428.aspx
Print Topic
Close Window
By gsimonelli
11 Years Ago
RDL content Error "Content downloader" Failed to connect to the internet.
New Displacement Power Tools for iClone
Just bought this and I can't download it. This has happened with other items that I bought that require this.
By duchess110
11 Years Ago
There is a thread with 2 others that have had problems with this content here is the thread.
https://forum.reallusion.com/Topic232069-230-1.aspx#bm232413
By rgathje
11 Years Ago
I was having the not connected to the internet issue with everything that used the downloader. I could get past it by going into internet explorer, tools menu(at the top), Internet options (at the bottom of menu), connections tab, Lan settings button, then uncheck use proxy server. If this lets you download then you may have the same issue I had. The problem is that I had to do this everytime I wanted to download something. I went into my programs and found I had a program that kept turning on the proxy server option. As soon as I uninstalled the program, the proxy server box stayed unchecked. I hope this helps.
