Character from DrawPlus X6 importing in CTA2
https://forum.reallusion.com/Topic230866.aspx
Print Topic | Close Window
By aletheia.fluitsma - 11 Years Ago
Hello,
Trying out pipeline and love it. But having a problem with importing my character. I get this massege:
"There are sprite and/or pivot issues present, see the Error Log for more info."
What do I have to do?
Also I cannot closing all my curves before importing. I see the icone but I can not click it. What do I do wrong?
The flash file template that came with pipeline is not able to open, but the other template files are working and this I intergrated in Draw Plus. I can export my character to flash with it when I confert my character to keyframe animation.
Thank you for answering
By vidi - 11 Years Ago
Good Question . Also I don't know what I have to do .
I ignore this message, because  I can not open the logfile , so there is useless for me.
Nevertheless, my Character works so far.
But I would know too,  What is the reason for this messages
By Ibis Fernandez - 11 Years Ago
aletheia.fluitsma (3/30/2015)
Ignore it. You will almost always get this error. If you are having issues then check the log file as it may give you clues but in general even when your character is perfect you will probably still see this message.
You done need an animation you just need a single frame.
