copy accessories to new computer?
https://forum.reallusion.com/Topic230156.aspx
Print Topic | Close Window
By sascheid - 10 Years Ago
Hello forum.
I just got a new computer. Installing the original program from the disc was easy but I need to know how to transfer content that I downloaded from the internet the new computer. I paid good money for some of these packs and I would like to continue using them. Any help?
By justaviking - 10 Years Ago
iClone?
Yes, what you want to do can be accomplished.  That I'm certain of.  I also expect someone with experience actually doing it will reply and will give you some good instructions and suggestions.
I would probably do it the most inefficient way possible, which I why I'm not giving any instructions.
Do you still have the old computer, and plan to run your software on both computers?  If not, you should "release" your license from the old computer.  The best way (for iClone) is to uninstall it while connected to the internet.  The next best option is you can "unregister" it via your Reallusion user account.
Good luck.
By animagic - 10 Years Ago
I believe the question was about content. What I usually do is make a backup of the content to a portable drive and then copy it back to the content directory of my new installation.
If it is the same version of iClone it is fairly straightforward as long is the path name starting with "Reallusion" is the same.
Thanks! You're advice was very helpful.
