Sneakers
https://forum.reallusion.com/Topic223653.aspx
Print Topic | Close Window
By EvilGenius - 9 Years Ago
I am in serious need of new G5 shoes, namely sneakers.
Do any of you all know how to make them? Or do you know of a good tutorial showing how its done?
By theschemer - 9 Years Ago
Check the market place as there are plenty of shoes for cheap.
http://city.reallusion.com/ContentPreview.aspx?i=JIC9d4e31e41e2ac0097
http://city.reallusion.com/ContentPreview.aspx?i=JICf9d6cc0f9c57e5f10
http://city.reallusion.com/ContentPreview.aspx?i=IC200D021ENU1101A001
And here is a little info on how to change the looks of them:
http://www.reallusion.com/contentstore/iclone/pack/clonecloth/Shoes_help.htm
TS
With all due respect, those are nothing like I am needing.
I attempted to make some out of some Nikes. (LeBrons)
The side looks okay but the other side doesnt.
I've been trying to edit them all morning trying to get them to look good. Obviously still need to work on them.
By colour - 9 Years Ago
You need to experiment with Shoes / Material / UV Settings. See Screenshot. I've deliberately skewed Chuck's trainers as an example.
BTW - You need to be careful using Nike's Trademark.
Screenshot:
By animagic - 9 Years Ago
What you could also try is launch the original shoe Diffuse map and then superimpose your desired map on it in a separate layer. You can then resize, move, and rotate the new texture as needed to try to get a fit.
