crazy talk pro 6 on netbook
https://forum.reallusion.com/Topic21944.aspx
Print Topic | Close Window
By lotvekemans - 17 Years Ago
I want to run crazytalk pro 6 on my netbook samsung NC10 but I get a message that the a 1076x 768 display resolution is requierd, but NC10 is running with a 1024 x 600 display. Can I solve this problem and does anyone know how?! I want to work onmy netbook with crazytalk so I can work evrywhere. Please help.
Lyt
By Peter (RL) - 17 Years Ago
Hi Lyt,
Crazytalk 6 does require a minimum resolution of 1024 x 768. I have not tried running CT6 on a netbook but unless you can change the resolution to the minimum I don't think it will be possible with the current setup process required by Crazytalk.
I will attempt to find out if Netbook support is planned but I think many of the current netbooks may not be powerful enough to run Crazytalk 6 anyway.
Hi Peter,
Thank you for your quick reply. And it is a shame it doesnt run on a netbook. If by any change this will change in future I would very much like to know. perhaps it will work if  I use an extern screen?
Lyt
