By kenmatthews - 10 Years Ago
Hello,
Having real trouble trying to get started with Iclone 6. My woes, which have been recorded elsewhere, is now compounded with my latest, which is trying to load one of my Iclone 5 projects. Here are two jpegs which show my problem. I may be doing something wrong, would really appreciate some guidance.
Best regards. Ken
By Postfrosch - 10 Years Ago
Hi Ken, you can NOT vns 6 files do not load more in iClone. Hence the old projects no longer walk. You must rename the vns files, depending on which type they are (iProp, iMotion, etc). Deione gezeichten files are 3 -Scenen. The file extension would accordingly Airport.iScene etc.
If you have avatars that have the extension .vns, you must first be defined in IC 5 store (they are then .iAvatar) Only then you can use them in IC6.
If you use your old projects again want you must first IC in 5 search what you used. If you have used such vns files, you have these parts in IC 5 only austaushcne save (to renamed files) the project again and reload in IC 6. Can sometimes pretty tedious to be (unfortunately) When I go approx 50% of the old projects no longer
Greetings from Germany Postfrosch (Werner)
Excuse my bad English. If only one goggle translation I'm already a bit older date and my Schuilzeit correspondingly long time ago
Hallo Postfrosch ,
Vielen Dank für Ihre Hilfe, ich werde versuchen, und meine Dateien zu konvertieren. Ich dachte, ich habe irgendwo gelesen , dass die Version 5 -Dateien können in Version 6 gebracht werden.
Freundliche Grüße. Ken
Hello Postfrosch,
Thank you for your help, I’ll try and convert my files. I thought I read somewhere that version 5 files could be brought into version 6.
Best regards. Ken
By animagic - 10 Years Ago
A number of older content packs have been updated for iClone 6, as listed here: https://forum.reallusion.com/Topic217045-385-1.aspx. Except for avatars, the VNS files can be "converted" by changing the file extension. There are some recent posts about that. I have to go to work now, but I will check tonight. EDIT: Cross-posted... Unless the iClone 5 projects contain older content (VNS files), they should import without problems. I have been able to continue my iClone 5 projects in iClone 6.
Hello Animagic,
Thanks for the reply. I did try changing the .VNS to .Iproject, alas it didn't work either...
Best regards. Ken
By colour - 10 Years Ago
kenmatthews (1/12/2015) Hello Animagic,
Best regards. Ken
Should be .iProject, Ken
By wires - 10 Years Ago
Ken, The packs have already been updated for iClone 6, you can redownload them from your account page. Take a look at the items in the link posted by animagic.
Ken, another user asked for a conversion list, which I compiled:I don't think I have ever seen a conversion list, but it certainly be useful. Let me see how far I get. All original extensions are .VNS, obviously. I only list the categories that still exist in iClone 6, as far as I can tell. - 3D Scene: .iScene
- Accessories: .iAcc
- Camera: .iCamera
- Character: .iAvatar; however this is one case where renaming often does not work
- Eyes: .iEye (currently for G5 only)
- Face: .iFace (currently for G5 only)
- FaceMorph: remains .VNS; only applicable to G5)
- Hair: .iHair (currently for G5 only; is considered an accessory in IC6)
- Hands: .iHand
- Light: .iLight
- Lower: .iLower (clothing is only compatible within generations)
- Motion: .iMotion (performance motions with extension .VNS may need extra care)
- Particle: .iParticle (particles were introduced in IC2)
- Project: .iProject
- Props: .iProp
- Shoes: .iShoes (clothing is only compatible within generations)
- Skin: .iSkin (currently for G5 only)
- Teeth became Oral: .iTeeth (currently for G5 only)
- Upper: .iUpper (clothing is only compatible within generations)
I think this is it... But, like Gerry said, content has been updated, which may be easier.
Also, occasionally I get a load error with projects as well. One thing to try is load an empty project first and then try again.
Hello Colour, Gerry and Animagic,
Many thanks for your help, I'll plod on and see if I can make any progress.
Best regards. Ken
By madicloner - 10 Years Ago
animagic (1/12/2015) Also, occasionally I get a load error with projects as well. One thing to try is load an empty project first and then try again. I got this with all my v6 projects. All. I only work with softcloth and no project worked. After loading first any v6 native project, it worked. Anyway this is a very strange issue and error. Else regarding project loading of v5: Randomly they work. Very simple projects are no problem - but if they use any special light or other features (which are now gone and deleted by RL), the project is dead!
