Organizing CT7pro Content Manager
https://forum.reallusion.com/Topic216657.aspx
Print Topic | Close Window
By BlueAlert - 11 Years Ago
I was in the belief that I was missing additional content. When I click on the folders within the main tabs - nothing happens. I am now thinking that the content did not go into the folders as supposed to but went into the main sub areas with the folders. If that is the case - is there a way to determine which file should be in a folder and then a way to move it into that folder. Even if that way is outside of the program with the results occurring in the program.
By Peter (RL) - 11 Years Ago
When you install content packs they should automatically be placed in the correct folders.
What content packs are you having trouble with?
Peter not to have you jumping back and forth between post - but yesterday you asked for a list of stuff you were going to tell me where to find. No answer no problem - so I kept looking and believe I found the stuff - not in the expected place. So it may require an uninstall and reinstall - but I pretty much brought the whole kit and kabuttle for the CT7. All of my folders are empty. The files are sitting along side the the folders.
