Indigo GPU Setting
https://forum.reallusion.com/Topic215117.aspx
Print Topic | Close Window
By gcshep - 12 Years Ago
When going from iClone to IndigoRT when inside the program it will not let me tick the GPU Setting however in the panel below it recognises my card and the questions is:
1.Does this mean it recognises my card or
2.Do I still need to tick the box?
Any help would be much appreciated.
Best Regard
George
A happy and prosperous New Year to all.
PS I have added a screen shot of the problem
By wires - 12 Years Ago
You need to stop the render in Indigo before you can enable GPU acceleration. It also needs to be stopped before increasing the Supersampling factor. Just click on the Render button to start things again.
By gcshep - 11 Years Ago
Thank you very much your suggested method works just fine.
By JC Weatherby - 11 Years Ago
Sequence Rendering: I notice when turning on GPU Acceleration inside Indigo RT,  GPU Acceleration TURNS OFF AUTOMATICALLY BETWEEN FRAMES.
Also:  Watching the machine monitoring tools I have, ASUS GPU Tweak, and Windows Resource Monitor, I notice that using GPU Acceleration takes some of the load off the CPU, but does not appreciably speed up or improve the quality of the render ~ in other words, there doesn't seem to be any real benefit to having this feature turned on.  Comments?
My System:
AMD 8350FX
Sapphire Vapor X R9 290 8GB DDR5
