CT 4.5 Hand Gestures Effects into CT 6
https://forum.reallusion.com/Topic21199.aspx
Print Topic | Close Window
By power - 17 Years Ago
Hi:
After lurking for some hours I finally found in one of my backup DVDs this effect that I used with CT 4.5. The app refuses to install because it looks for a CT 4.5 installation. Since I have a backup of the Hand Gestures template ditrectory, Where I can copy it into CT 6 so I can have those effects available? I don't want to install CT 4.5 to solve this.
TIA
:cool:
By Peter (RL) - 17 Years Ago
I don't have this pack to hand but it will probably go into either ComicEffect or ComicEffectCSM folders which can be found in the Crazytalk 6 Template folder.
Hi Peter:
I try at both locations, no working.
:doze:
Hi:
Ok, finally found the proper location. It goes under shared templates/script/Hand Gestures.
Later
Glad you got it to work ok.
That is not the common install location for content packs but if it works that is the important thing. :)
