camera not recorded
https://forum.reallusion.com/Topic206973.aspx
Print Topic | Close Window
By exobnkr - 12 Years Ago
Hi. I Followed both CTA1 and CTA2 tutorials on Youtube. here is my probleme :
when i have finished recording the movement of the caméra, it is not recorded.
I press camera "record mode", move the camera, place keys on the timeline, i can preview the movement in the "record mode" BUT when i go out of the "record mode", the movements of the camera are not recorded when i play the animation.
Thanks for your help.
By AverageJoe - 12 Years Ago
That's because you have to be in record mode to record the camera stuff. If you're not in record mode, you're in stage mode, which you can export your video from, but it exports via the stage mode. Export it while in record mode, and you'll get your camera movements.
wizaerd (11/26/2014)
I think i have tried once to export while in record with no better result. But, i am not really sure. I try again tonight and tell you what happened. Thanks for your help.
i retried with another more simple animation and it worked with your helpful piece of advice. I go back to my big animation and do the same. Thanks a lot for your quick help. Rgds.
