Tutorial by John Martin on how to use Autodesk Character Generator in iClone
https://forum.reallusion.com/Topic202469.aspx
Print Topic | Close Window
By animagic - 12 Years Ago
Here is a tutorial for you from the horse's mouth! :w00t:
http://www.3dartistonline.com/news/2014/10/3d-masterclass-iclone-character-animation/
Should be fun...:D
By Rampa - 12 Years Ago
I've done a few of these. There super easy because you can characterize them with one-click. They use the HumanIK template.
The high resolution skeleton gives you breast, buttocks, and belly bones that you can map as extended and add spring to.
There are no eyelashes, which is more noticable than you would think.
Just found out that the basic (free) version doesn't seem to give you facial bones or blend shapes... :crying:
That was different with Pinocchio. I have a few of those.
EDIT: Actually, the only problem is that I don't see a jaw to map. The bones in John's character are the same as mine as far as I can tell.
