Physics Toolbox problems or is it?
https://forum.reallusion.com/Topic201663.aspx
Print Topic | Close Window
By rampart - 12 Years Ago
Project requires very fast fans in tunnel. I have been working with the physics toolbox to rotate the fans (large exhaust fans) in the tunnel. I can't get the speed up beyond a turtle creep. I did the advanced thing with speed and multiplier and still the max speed is 30.
Maybe this is a bug, maybe that is top speed. I don't know, but it won't work as is.
Yes, I can do this with the timeline I am sure, but it is annoying to think after almost two years I finally have a use for the toolbox and what I need doesn't cut it.
I looked for some video tutors, I even looked at some content items that use the motor A and they don't work any faster either.
Anyway, if you know the secret...I would appreciate, if you would share it. :w00t:
By mark - 12 Years Ago
Once the physics simulation has generated it's animation file. You could go to the timeline and adjust the speed of the animation by "shorting/squeezing" the animation clip. Then be sure to turn off the physics simulation.
Right..
I was thinking it was going to be my timeline problem.
Think I'll just blow of the physics and rotate the fans with keyframes.
0,90,180,270,0
Thanks for your response
By Rampa - 12 Years Ago
Not that really matters, but thirds will work as well as fourths.:)
By Cricky - 12 Years Ago
rampart (10/20/2014)
Right..
0,90,180,270,0
For a better "Looping" rotation... Try 0, 179, 358, 0 Then copy and paste
