Will iClone 6 have any new animation tools?
https://forum.reallusion.com/Topic199169.aspx
Print Topic | Close Window
By Rampa - 11 Years Ago
Curious if there are new animation tools this time around, or is this just a huge rendering engine upgrade?
Couple things I would hope to see are onion-skinning for better alignment, and rotation alignment that works with the align tool in the right click menu of the timeline. Hopefully it would use the avatar's chosen alignment bone and orient it to the alignment (rotation) of the same bone in the previous clip. It would need to be the temporary top of the IK chain for this to work, I guess.
By planetstardragon - 11 Years Ago
yep! https://forum.reallusion.com/Topic164038-298-1.aspx
Ahhh, yes!
I wonder if it will be a window full of colored lines like some others, or a curve associated with each track like a music sequencer?
However it's done, it should help with timing, strength, etc. of animations.
We really need the masking tool at the outside level as well, rather then inside the Motion Puppet tool.
By prabhatM - 11 Years Ago
Is the "new rendering engine" going to be the "killer feature" of ICLONE 6 ?
Or, something that no indication has been given so far ?
By animagic - 11 Years Ago
prabhatM (9/25/2014)
Indigo RT as you have probably seen by now...:w00t:
