Swap import image without refitting
https://forum.reallusion.com/Topic198023.aspx
Print Topic | Close Window
By Anonymous - 12 Years Ago
I would like to suggest the option to swap out the import image (avatar) without needing to refit the model.
I have rendered various versions of a game character from a 3D model to animate in CrazyTalk. I plan to allow the user to select options to "customize" the look of the character, change the skin/hair color, add simple clothing props, etc. The model isn't repositioned, the artwork is nearly identical, but when I import the new image into CrazyTalk I am forced to reposition every fitting point again by hand. I also lose all the eye and teeth settings. Please allow the option to swap out the import image without the need to go through the entire process of setting up and fitting again.
By Peter (RL) - 12 Years Ago
Thank you for the feedback. This will be passed to the CrazyTalk team for consideration. :)
By sethbang - 12 Years Ago
Yeah, this is a must-do and kind of an obvious feature. It's an obvious enough feature that the developers of Reallusion Animator thought to include it. See here.
By JOHNAVATAR.com - 11 Years Ago
That must be on the PC version? I don't see the "Replace Image" button for Mac?
By Anonymous - 11 Years Ago
JohnAvatar (1/19/2015)
And exactly where is that "Replace Image" button on the CrazyTalk 7 menu's?
CrazyTalk Animator is a different program.
