Hi Guyon,No this isn't possible I'm afraid. If you wish to manually apply makeup, then you would be better to use an image editor like Photoshop, PhotoPlus, Gimp etc.
FaceFilter is designed to take away the hard work of manually applying makeup and automate the process by a one time setting of fitting points. Once the fitting points have been correctly placed you can make as many changes as like to makeup with just a couple of clicks in Content Manager.
FaceFilter 3 will work best when used with front facing neutral portrait photos. The face fitting process will not work correctly with faces that are at unusual angles or faces that have strong expressions.
