By gcshep - 10 Years Ago
Hi I have my biker Avatar and I have set in it a pose of sitting on a motorbike and shall be using the same Avatar with the same pose in a later scene however I find when I save my Avatar with this pose in the custom content manager under the Avatar tag and then when I come to reuse this avatar with the pose it has only saved the Avatar and not the pose with it.
The question is are you able to do this and if so could anyone point me in the right direction as to how to carry out this operation.
I have attached an image of the Avatar in the pose.
Best Regards George
By mark - 10 Years Ago
If you are using iClone Pro you will need to open the Timeline(with your avatar selected) then click the Motion tab and the Collect Clip tab. In the Collect Clip area drag out a selection with your mouse to include the clip you should see in the Motion area (that's the animation or pose you have created) then Right click on the selection you made in the Collect Clip area and save the selection to your Motion Library...it sounds a bit confusing to read but once you do it it's pretty straight forward...
Mark thank you very much for your help it works a treat.
Best Regards
George
