CrazyTalk Animator 2.15 Released (PC)
https://forum.reallusion.com/Topic188942.aspx
Print Topic | Close Window
By Peter (RL) - 12 Years Ago
CrazyTalk Animator 2 Windows Version History
v2.15 (v2.15.2328.1) released 4th December-14
  • Content Downloader v2.0
    • Added: Added Content End User License Agreement (EULA) for user viewing on first download.
    • Fixed: Allow choose only one product for the cross product content (.iMotion) in Product Version Selection.
    • Fixed: Avoiding iClone Motion (.iMotion) installed into CrazyTalk Animator 1.
    • Enhanced: Enhanced the stability for the large file while downloading.
  • Added: Add "Additional Voices" link in TTS dialog for experience the "TTS On-Demand" service.
  • Enhanced: Enhanced the performance in timeline for "Object-related Track".
  • Fixed: Scene (.ctScene) not allow picking and applying Render Style.
  • Fixed: Fixed the content compatibility for object with layer key (Ex: Hilltop Church pack).
  • Fixed: Some CrazyTalk7 script cannot load into CrazyTalk Animator.
  • Fixed: Updated embed content “Eyes_04.cteye” for fixing 45 degree messing left eye.
v2.14 (v2.14.2027.1) released 1st September-14
Content Downloader v2.0 released
Users are now able to install iMotions outside of the iClone environment.
Enhanced: Download stability to allow downloads of larger amounts of content.
Enhanced: Installation flow to produce a better installation report.
Fixed: Save project cause possible crash while HD space is low.
Fixed: Fixed the possible crash when continually using undo/redo in Mask Editor.
You can download the 2.14 patch from your Member Account under Patch/Bonus.
v2.13 (v2.13.1921.1) released 22th July-14
Enhanced: Enlarged output resolution in PC 64 bit and MAC, now allows 4K video (3840x2160, 4096x2160) export.
Other Issues:
Fixed: When using Retina display with dual monitors, the main view will not update when dragging it between two monitors.
Fixed: When using Retina display with dual monitors, some menus and their sub-menus may inadvertently split.
Fixed: When looping a voice clip in timeline, the sound wave view shows incorrectly.
Fixed: Real-time Vector Render Quality in the Preferences settings resets when program re-opened.
Fixed: When multi-selecting objects with different Z values, edges may be cropped.
v2.12 (v2.12.1811.1) released 12th June-14
Enhanced: CrazyTalk Animator now a Native 64bit program in MAC OS.
Enhanced: Enhanced animated GIF rendering stability.
Enhanced: Character voice support now stereo when exporting to video.
Fixed: Removed Facial Clip in Timeline on morph-based head characters, it now removes the animation data properly.
Fixed: Added lips key to auto extend the Voice Clip, the wave view was incorrect.
Fixed: Deleting a sprite in Composer Mode and continuing to click undo caused system crash.
Fixed: Photo background moved when calibrating in fitting panel.
Fixed: Export video slowed down after frame 123. (PC 64Bit only)
v2.11 (v2.11.1712.1) released 13th May-14
Enhanced: Enhanced the gif export quality.
Enhanced: Smooth Quick Capture result by using high vector render quality
Crash Issue:
Fixed: Applying G1 body part to G2 Character causes possible crash.
Fixed: Face Fitting save or del character then undo causes possible crash.
Fixed: Program possible hang while initialing and switching windows to another AP
Export Issue:
Fixed: Export area does not match the Safe Area.
Fixed: Export video failed in PC 64bit with UAC tune on or run as non-administrator.
Fixed: Once use Render > Current Frame Preview, the Vector Render Quality always goes back to Low in Preference Settings.
Fixed: Timeline range indicator not updated when Quick Capture Animation panel opened under some conditions.
Fixed: Gif export for half transparent object possibly results in incorrect color display.
Fixed: Gif output failed for high resolution and large project.
Other Issue:
Fixed: Press Space key to stop playing sometimes does not work.
Fixed: Audio wave graphic is stretched while adding a lips key to make the audio clip auto extend.
Fixed: Duplicate Text object and multi select to move causes incorrect bounding display.
Fixed: Performance issue for "GrA_Aisle_side_right reflection.ctProp" in "Scene_Grocery_Aisle" content pack.
Fixed: Transition Curve and Time warp Curve editor always behind the timeline.
Fixed: Morph-based head does not work with Layer Editor.
By AnimatFolks - 12 Years Ago
I have to install the version of 495Mb and then the patch or just the patch?
Thank you.
AnimatFolks (7/24/2014)
Thank you.
If you have CTA 2.12 installed already you just need to install the 2.13 patch.
Ok. Thanks Peter
By schaal - 12 Years Ago
Peter, do you know whether the animated gif / pptx 2010 issue (i.e. high render quality animated gifs are not properly played back in pptx, but stop prior to the end of the scene) is also fixed? (Since I have the german version I cannot test it, yet.)
schaal (7/27/2014)
In my testing (with CTA 2.13 and PowerPoint 2013) there are no issues even at the highest setting.
Please can you let us know the exact steps you are taking when the error occurs. We will then try to reproduce the problem in PP2010. Thanks.
I simply drag e.g. Emma_Angry from the Perform Learning Kit folder onto the stage and render it (Quick Capture), then click transparency, frequency 15, frames 1 to 152, Looping Options: 1 and paste it into pptx 2010. Nothing else. Starting the pptx presentation Emma runs until approximately frame 50 and then prematurely stops. (However, since I'm working with the German version, which unfortunately is always behind and RL is not willing to change from the German to the English version without paying additional money, I cannot test CTA 2.13 yet).
Anyway, it seems that I'm not the only one having problems with the animated gifs cf. the forum topic: CTA 2.12 and PowerPoint 2010
Heiner
schaal (7/28/2014)
Heiner
Thank you for supplying more information. I have passed this to the CTA2 development team to investigate. As soon as I have more information I will update again.
Any idea when the German CTA 2.13 update will be available so that I can test whether the animated gif issue is fixed with this update?
schaal (8/2/2014)
Unfortunately I don't have a confirmed date but hopefully it won't be too long now.
In the meantime have you tried rendering the Animated GIF to a file instead of using copy and paste?
You can go to Render > Render Image and then choose Sequence and GIF as the options. Does this play the full length of the animation when opened in PowerPoint 2010?
This, at least seems to work for the whole sequence. However, the resolution is pretty poor (equally achieved otherwise if the quality is set only at 1 or 2). This low resolution is not acceptable having the advertisement in mind.
schaal (8/4/2014)
Try checking Super Sampling. This might improve the output quality. The Animated GIF below is 560 x 315 and shows pretty good quality using these settings.
This was a good tip! Super Sampling indeed improves the output quality. And to get a comparable frame rate one has simply to change the frame rate from 30 to 15. Otherwise in pptx 2010 it plays much too slow.
By alplymale - 12 Years Ago
Hi My Name is Al Plymale and we are looking for some talented people that can use this CTA2 Software to do some animated videos for our company. If you are verse in using this software, can write script, and do so in 2 minute or less videos we would like to talk to you.
Thanks
Peter, unfortunately the pptx 2010 is still not completely solved! (Even though it worked for Emma_angry.) Following rendering with the same settings but now with composed clips but also only 170 frames in total, sometimes there are black frames in the pptx presentation inbetween. Initially I thought this might be due to specific sprites, but the black frames seem to appear irreproducibly. The problems start when I tried to include a subtitle. Any idea?
schaal (8/5/2014)
Sorry to hear your problems continue.
Can you please contact us at Support and let us take a look at your outputted file. If you use the support form below and explain the problem we will certainly look into this issue urgently. Thanks.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
alplymale (8/5/2014)
Thanks
Hi Al,
Might be worth making a new topic with your request in the CTA General forum below. This will get the most views.
https://forum.reallusion.com/Forum356-1.aspx
Good luck with your search. :)
schaal (8/2/2014)
We are now looking towards the end of the month for the German 2.13 update. Not too long to wait now.
By cbyas - 12 Years Ago
Exactly what does that mean?
schaal (8/2/2014) Any idea when the German CTA 2.13 update will be available so that I can test whether the animated gif issue is fixed with this update?
answer: Unfortunately I don't have a confirmed date but hopefully it won't be too long now.
Since CTA 2.14 is now out, and currently the official German version is still 2.12, is there any idea whether the German version will be updated any time as well ????
By Luna - 12 Years Ago
Hi schaal!
schaal (9/6/2014)
Susan said in the German forum, the update comes this following week (september 8 until september 14):
https://forum.reallusion.com/Topic197701-258-1.aspx
Yes, it is a long delay... :doze:
Luna
Luna, thanks for the hint. I will never understand why RL makes such an issue out of language versions...
Anyway, there is still the question unanswered what does it exactly mean that 2.14 is now able to install iMotions outside of the iClone environment. I don't understand that either.
By jlittle - 12 Years Ago
schaal (9/7/2014)
...what does it exactly mean that 2.14 is now able to install iMotions outside of the iClone environment.
I believe it means that you can now install and use iMotions in CTA without having to own or install iClone as was previously required.
Jeff
cbyas (9/6/2014)
This refers specifically to the Marketplace. If you purchase any iMotions, you will get the option in the Downloader to install to CrazyTalk Animator 2 Pipeline now instead of just iClone. :)
So if we can do this now without iclone. What happens to those of us who had to purchase iclone in order to get this feature? If its now available in CTA2 what of those of us who paid for pipeline? just saying
