This can be done i Max. Make scene. add animations, diffuse maps, opacities and export as 3D scene. Just like the way I advised as to the cat problem Spider. Another way is to use the building block props and put your diffuse maps on and merge the props. Once merged save in custom folder. This would still be a prop but you could open as a 3D scene using your browser.
