How to animate ?
https://forum.reallusion.com/Topic1872.aspx
Print Topic | Close Window
By Spider_Mycron - 19 Years Ago
Greetings ,
i have no idea how to animate a cat , a horse , a bat .. just any creature non human inside of Iclone ?
like if i animate something in poser ... am i able to bring the model (obj maybe) and the bvh ? i know it's possible for this ,
but how to apply the animation i make to the prop i got in iClone?
how to apply a custom animation to a custom prop please ?
need your kindly help i really lost in this
Best Regards
By Popeye - 19 Years Ago
If there is animation on a custom prop you will find it by selecting the prop and then go to Modify. Switch on the timeline and then right click on the timeline. If whoever made it put animation on it you will see the options.
Thanks for your kindly response,
what i mean is .. if i have a cat in poser , i wish to bring it to IClone after it done with animation in poser ...
i have no idea how to assign the animation file to it after bring it to iclone
but what i think is , get it inside 3dmax, export it to iClone then apply the animation file
am i correct , any other idea ?
Regards
If you can use MAX and have the plug-in it is best to do your boning and animation in this. When after bringing in your mesh, bone the cat. When going to export to VNS click on the animation tab. This will give you the option to save a number of different animations by allocating which frame numbers for each animation. Remember to name the animation for each one.
e.g. Frames 0-600 cat walk
       Frames 601- 650 cat sit
When exported and then iclone open timeline and right click and you will see the animations you have put on in Max. You could then get the cat to walk and then sit down using the key frames in iClone's timeline.
Hope this makes sense and can help you.
Regards
Popeye
yah . just fantastic answer
many thanks
Glad it made sense to you Spider:)
