Mask Undo and 24 bit
https://forum.reallusion.com/Topic186152.aspx
Print Topic | Close Window
By Guyon - 12 Years Ago
Masking:
FF needs an undo when mask painting. I know you can erase but then you can make even more mistakes hampering productivity.
64bit:
I am guessing that the program is not 64bit as it is a little sluggish even on a Quad core windows machine. This especially effects making, causing mistakes as you paint. So a 64bit option would be especially nice.
By Peter (RL) - 12 Years Ago
Thanks for the feedback. :)
For the masking issue, you can use the general undo from the top toolbar (CTRL+Z). This will remove each step of the masking process if you make a mistake.
