Hi,Thanks for updating the situation.
Have you tried a far different variation in frame rate to see what happens. For example setting the frame rate to say 10 - 15 should give a vastly different results in total frames outputted.
Also have you found this problem occurs in all your projects or is it restricted to a single project?
As I mentioned before I have been unable to reproduce this problem with either Crazytalk 5 or Crazytalk 5 Pro. For further help with this issue you can report it to our Technical Support department who may be able to offer some guidance on the possible cause.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx.
