Can't convert to non standar charecter in 3dxchange
https://forum.reallusion.com/Topic176503.aspx
Print Topic | Close Window
By prahaladh.sachin - 11 Years Ago
I have a problem.When I import maya charecter in 3dxchange the "convert to non standard" option is disabled......What should I do
By Am7add9 - 11 Years Ago
without a screenshot, hard to say.
my first guess is no bones.
is the "non-human" option available? try that first. convert it and see if non standard becomes available
I have attached the screenshot.......As you said when i convert to non human still the "non standard" option is disabled......Thank you for the kind replyImage and video hosting by TinyPic" border="0">
Finally I found solution for the problem.The main problem is I am using iclone 5.1 and my 3dxchange version is 5.5.....Now I Installed iclone 5.2 and 3dxchange 5.2 it works fine for me.............:D
By Peter (RL) - 11 Years Ago
prahaladh.sachin (2/2/2014)
The latest version of iClone and 3DXchange is 5.51. You are missing out on a lot of new features if you are using version 5.2. You can update to the latest version of both titles by going to Help > Check For Update. :)
