iClone 5.51 Update Released
https://forum.reallusion.com/Topic168495.aspx
Print Topic | Close Window
By Peter (RL) - 13 Years Ago
iClone Version History
v5.51 (v5.51.3507.1) released 15th November-13
  • Added: Compatible with Avatar Toolkit2 Series (eg. Monster Workshop I Repack / Toon Maker).
  • Fixed: Reduced random crashes in the 64 bit version when using Motion Puppet & Timeline Editing.
  • Fixed: Importing characters caused crashes after plugging/unplugging the earphone jack.
  • Updated: Update Height Map Terrain in .iScene files, to make them compatible with the updated iTerrain from 5.5.
v5.5 (v5.5.3207.1) released 8th August-13
  • Added: 64 bit version of iClone officially released.
  • Added: Added .wmv(VC-1) and .mp4(H.264) output to 64 bit version.
  • Added: Added iMotionPlus format (Contains Motion, Facial Animation, Visible, Spring and Sound).
  • Added: Added Bake Constraint key (Including Path, Reach, Link, Contact and Look at).
  • Added: Added Translate (Stretch) Bone option to Motion Layer Editing.
  • Added: Now able to edit Height Map Terrain including Height Map layouts and textures.
  • Added: Added the Level-of-detail Options for Height Map Terrain in Real-time Playback & Editing.
  • Enhanced: Height Map Terrain Physics; added Collision Margin, Friction and Elasticity.
  • Enhanced: Facial Creation Tools Enhanced:
    . Control points for facial fitting optimized.
    . Viseme visual quality enhanced.
    . Added animated tongue.
    . Updated interface for side-facial fitting.
  • Fixed: Lipsync lost frames during playback if the audio length was over 60 seconds.
  • Fixed: Added back Spring Effect for Gwynn character.
  • Fixed: Fixed the lip keys to show "None" when loading old iClone4 data.
  • Fixed: Fixed inability to adjust the transition length for Reach/Spring Key.
  • Fixed: Fixed Insert Frame in project track did not affect the Animation Layer track.
  • Fixed: Fixed iClone4 project tendency to use embedded textures as external textures, resulting in inability to find textures in iClone 5.
  • Fixed: Fixed sequence image output failed in some special environments caused by hard disk space misjudgment.
  • Fixed: Fixed Human-IK editing issues in iClone Standard Version.
To update please select Help > Check For Update in iClone. Alternatively you can Login to your Member Account and download the update by selecting Patch/Bonus in your list of Registered Products. The update can also be downloaded using LiveUpdate.
By vidi - 13 Years Ago
Can it be that after this update the water is broken ? My Water looks strange and is not moving more
I have no normalmaps effect more and if i load a scene and will load water, iClone is crashing . Also i can not more open a old project, only crash . I have reboot my system but is the same
By RB3006 - 13 Years Ago
My water is working :w00t:
Robert
OK, I think I have resolve the problems . In the preference was only LOW 256*256 now
I have reset on High again and it seems to work now :hehe: No crashing more and nice looking water :)
vidi (11/16/2013)
Thanks for letting us know everything is ok now. :)
Indeed 256 x 256 is not recommended with iClone 5.51 as it does cause some display issues.
By hirospot - 13 Years Ago
Regarding Dance Motion Tracing
Thank you very much for iClone5.51 Update, especially for reducing of Random crashes when using Motion Puppet & Timeline Editing.
It was really reduced remarkably.
Thanks to the 5.51 update, I could continue the Motion Tracing work. I was almost about to giving up on the tracing work before because of many many sudden AP crashes and reworking hundred times.
Please find my latest trial report for Motion Tracing by iClone5 Key-Frame Animation. [Report] [DemoVideo]
Thank you again to the RL teams,
Hiro
