By gp0778 - 13 Years Ago
Cannot Load Invalid Data, Cannot Load Invalid Data.............continue this a few dozen more times.
This is the message I get all the time when I try to import an iclone file as a terrain map from Earth Sculptor. This is driving me nuts!
Ehh, so what's the deal with this?
By richinri - 13 Years Ago
I just had this happen for something from the content store. The file was verified as corrupted and replaced by the seller.
By sjonesdc - 13 Years Ago
gp0778 (9/28/2013) Cannot Load Invalid Data, Cannot Load Invalid Data.............continue this a few dozen more times.
Sometimes, posting on the forum some of the more experienced iCloners can give some guidance to solve the problem,however, if you purchased an item from the Content store, you should contact Reallusion Customer support, and if you purchase an item from the Marketplace, then contact the seller.
By DELETED2 - 13 Years Ago
OK GP0778, this should be a simple one but first you have to tell everybody the settings you used to create your landmass and then export. Otherwise we cannot see whre the error lay. As much detail as possible please.
By Peter (RL) - 13 Years Ago
Ehh, so what's the deal with this?Earth Sculptor exports as Props not Terrains. Just go to Set > Props and import the Earth Sculptor *.VNS file. It should load correctly then. Once loaded you can then save it as a Terrain.
By el443925 - 10 Years Ago
bought the Realistic Human 100 Pack Pack and installed it, but when I try to apply a head in Character Creator or Iclone, I get a "Cannot load invalid data" error. Who can help me with this problem
By Snarp Farkle - 10 Years Ago
el443925 (5/13/2016) bought the Realistic Human 100 Pack Pack and installed it, but when I try to apply a head in Character Creator or Iclone, I get a "Cannot load invalid data" error. Who can help me with this problem
See this thread for a link to an updated RLDownloader.
Link
By nkkiiru - 10 Years Ago
I have this problem too, I have run this app http://file.reallusion.com/Downloader217_Enu.exe but the problem is still there.
By info_79_89_41 - 9 Years Ago
the tutorial said character creator accepts OBJ, yet I get a message:cannnot load invalid data.
