Installing FaceFilter Pro on Windows 8 Pro System
https://forum.reallusion.com/Topic164035.aspx
Print Topic | Close Window
By kevinwelty - 13 Years Ago
After having purchased the FaceFilter Pro Special early this morning, I have been unable to install the program.  It seems as though the Install program thinks that installing it on Windows 8 that it is being installed on a virtual machine.  The install progam halts at htis point and will not go further.
However it is implemented, all I know at this point is I paid for a program that they refuse to let me install on my current system.
No response from Reallusion yet, but I am surprised there is not more reports of this type of problem.
Anyone with advice, please let me know.  Greatly appreciated.
Sincerely,
Kevin W.
By Peter (RL) - 13 Years Ago
Hi Kevin,
Please check if you have HyperV turned on your Windows 8 computer. This is known to cause this false error message within Windows 8.
If you do have HyperV running, please do the following to resolve the issue until a permanent resolution is found.
1. Go Control Panel > Programs > Turn Windows Features On or Off
2. Disable HyperV
3. Install FaceFilter 3.
4. Repeat steps 1 & 2 to enable HyperV again.
This should resolve the installation problem.
By Wesco - 12 Years Ago
Hey, the Problem is still present. Are you working in an solution?
By Peter (RL) - 12 Years Ago
Wesco (11/26/2014)
Hi..
Please try the steps given in my post above. This should resolve the problem.
