Watermarks
https://forum.reallusion.com/Topic160765.aspx
Print Topic | Close Window
By AndyM - 13 Years Ago
I have purchased B006A Jack Clone Bodysuit B2, but when I try to use it with Jack Cone Cloth I still see the watermarks and it shows as Trial in my Character List.
By colour - 13 Years Ago
In iClone Program, go to; Help drop-down / Content 1-Click Verification.
Try that.
Anyone-else?
still the same result. I am using iClone 4 btw if it makes a difference.
By SchachMatt - 13 Years Ago
Hi AndyM,
last year I had a similar   situation with version iCl5. Since the "Content 1-Click Verification" did not solve the issue, I send a Support Ticket.
The Technical Team of RL was of great support and helped to solve the issue.
Maybe you also go this way?
BR,
SchachMatt
By rgathje - 13 Years Ago
  I think you need the Bodysuit base to remove the watermark. If you look under the description part of the bodysuit B2 you should see a required item of the bodysuit base.
"rgathje (8/12/2013)
  I think you need the Bodysuit base to remove the watermark. If you look under the description part of the bodysuit B2 you should see a required item of the bodysuit base."
See Screenshot of Trey Bodysuit B Upper & Lower Cloth Base & Bodysuit.
IMO, the Upper & Lower  Cloth Bases would be included, since the Bodysuit wouldn't cover the Body correctly if they weren't. You'd have gaps of flesh showing.
However, It depends how you acquired the Bodysuit in the first place?
Screenshot:
