Move and Rotate bones
https://forum.reallusion.com/Topic154429.aspx
Print Topic | Close Window
By Marto19 - 12 Years Ago
I have imported a character in fbx format from MotionBuilder(which I don't have).
When I create the non standard character in 3dx5 and select a bone's node I can rotate it but the move is grayed out.
How can I move the bones?
By kungphu - 12 Years Ago
I'm not sure what you are trying to do or what motion builder you are talking about. My biggest suggestion is to spend abou an hour watching a YouTube tutorial (try warlord's or panthers tutorials) and really understand how 3d exchange works. You have to rotate the bones in the t-pose and specific the bones to a specific rig when setting up your character for animation. I was pretty lost at first as well until I started taking the time and watching tutorials.
By Peter (RL) - 12 Years Ago
Marto19 (5/5/2013)
You can't move the character bones in 3DXchange5. The actual positioning of the bones needs to be done in your 3D modelling software prior to export to 3DX5.
By Cricky - 12 Years Ago
Just a quick Note:
Make sure the character is not "Active" as a Non-Standard, and then you can manipulate the bones. Just, not while the "Active" phase is checked.
By R Ham - 11 Years Ago
This looks a lot like RTFM - but there's no M! :-)
By dogged2003 - 7 Years Ago
Peter (RL) (5/20/2013)
Marto19 (5/5/2013)
Why this not work for any bone? #7 at the end...
http://manual.reallusion.com/iClone_7/ENU/Pro/Default.htm#iClone_7/Pro_7.0/11_Set/Prop/Translate_Bones_for_Props_and_Accessories.htm%3FTocPath%3DScene%2520and%2520Prop%7CScene%2520Build-up%7CProp%7C_____13
By animagic - 7 Years Ago
@dogged: That section talks about props, not characters.
animagic (8/1/2018)
Very interesting why? This effect is used in animation. This effect is very necessary.
