Fade In - Out
https://forum.reallusion.com/Topic15278.aspx
Print Topic | Close Window
By Apparition - 16 Years Ago
Many users want to do a fade in or out effect in their videos, and are NOT using a video editor program, but want to do it right inside iClone.
Here it is how to do it!  (Print this step-by-step guide to make it easy to follow)
First we must create and save a FADER plane iProp...
- Create a bare new project.
YOU WILL DO NEXT PROCEDURES JUST ONCE IN YOUR LIFE!
- From the Set menu select props
- Go to the 3D Surface section
- Double click on a Plane_A surface.
- Reset the view with the F key as to have the A Plane centered.  It will be light blue in color.
- Go to the Modify Panel, and scroll down to where the material texture windows are.
- You will see the bluish texture diffuse material box.   Select it.  Will show a thick frame around.
- Launch you image editor. (You must have an editor assigned at the configuration menu)
- The texture Diffuse image (light blue) material will pop at the image editor.
- Fill it with black.   Save it, then go back to iClone.
- Now, using the disk icon save this black image for future usage in a convenient folder.
- Next, select the Opacity box and load in the just saved black image.
- You are ready now.  You will see the A_Plane looks black in the work window.
- Save this Iprop  with a FADER PROP name!
AT THIS POINT YOU HAVE YOUR FADER PLANE DONE.
YOU WILL NEVER NEED TO REPEAT WHAT YOU DID (unless you forget to save it!)
TO USE YOUR FADER,  YOU LOAD IT IN A PROJECT, THEN:
- At this time you must move the plane back, using the object position tool, until it covers the whole screen.  All scene elements should be behind the Fader Plane.
- Move the time slider to first frame.
- With the Fader Plane selected, at the Modifier, Opacity Strength move the slider to 0!(to create a key)  (The screen will look black!)
- Now move the time slider to an advanced frame (90 frames for 3 seconds)
- Again at the Modifier, Opacity Strength, slide it up to 100...  (Now you totally see the scene)
- Now try it!.   Slide the time slider from frame 0 to rame 90.  You will see the scene fading out!
- To complete the fader, scroll up at the Modify window until you find the Display section.
- Being sure you are stopped at last Fade Frame (91 in this example) Turn Visible OFF . This helps iCLone as not to "render" an invisible frame!
NOW YOU HAVE A FADE IN READY SCENE!
You must place all your characters and scene components behind the A_plane. (deep inside)
When you run the animation The scene will start black and slowly fade in!
You can do the same but in an opposite way to make a fade out. Also you can use any other color or texture for the Diffuse map, as to fade from blue or white or whatever!.
- Remember to SAVE your Fader Plane Prop for next time, or you will have to do it again!
Have fun fading In and Out! ;)
Mike
By Cricky - 16 Years Ago
Basically turning a light switch on with a fade in control, right? Isn't that the effect you are after, or am I interpreting wrong?
It would be easier to just fade in from Frame1 with a Black Light to the point where you want the White Light (or other by choice) to show all; say at Frame 500. The Light can be saved as a Custom Light to re-use.
eg.
Light1
Frame 1 - Light Color = Black
Frame 500 - Light Color = White
The light transitions as the time line passes by to go from Dark to light.
Am I over-thinking this? Each light retains it's changes over the time line as the scene plays out, so it seems a lot easier to just change the light color as the scene progresses. Custom lights can be saved and don't require a lot of resources either.
Nop Cricky!
I am not after anything!   I am solving some visitor's questions on how to do a Scene Fade In Or out, like those you get with a video editor package.
Changing lights would be much more difficult, because very seldom you use only one light.  Also the effect on lights going down is not the same as a fade.  A fade as those you see in the movies all the time!
The procedure I am describing here is not at ALL difficult!!  It just looks like, as I describe step-by-step without omitting a single detail.   Once you have created your "Fader" prop, you don't need to repeat the process at all.  Just load the prop, and set the  in and out keys for the fade to occur.   And the simple plane practically takes NO resources!
With this you can make fade layers for instance!   You can have a front plane, with a landscape as background, (mapped onto the Fade Prop).  When you fade it away... Pop! You can see what is behind!   And could also have more, revealing one by one back planes!
To slowly remove a cloudy atmosphere for instance!  Many things!  But mainly... To simply Fade in and out!
How would you do all this effects with lights?
(Also... You would have to diddle with the ambience light,  remember?)
Light manipulation is definitely NOT the way to go!
Someone agrees or disagrees here?
By Flybynight - 16 Years Ago
Thanks for that info even though I did not post the question. I am gradually learning more thanks to you guys.
OK, your method does work.
The intention of the post was not to say it did not. The lighting of a scene using the Spotlights as directional lights can be used also. it was presented as an option to your method. Custom Lights can also be saved for re-use later.
To show you that your prop does work, I have created it and am giving it away here for those that don't want to decipher the instructions. See Attached.
There is also the option of doing it in your video editor, post production...which is the way I usually use a fade option. Regardless of the choice, there are always options.
By gizmo - 16 Years Ago
Thanks Cricky for the download - I'll try it just for the hell of it - and Mike for the idea - it may open other doors and in any case additional options are always welcome.
Perfect - could possibly be used to bring in a 'ghostly' character into or out of a scene due to lack of opacity slider for the head !!
...and to add a twist to it, seeing as how it's Valentines Day Tomorrow...here is a Material File for those of you that are procrastinating... Just open the Fader and apply the Material File from wherever you save it.
See Mike, it did generate some interest!
p.s. The Material File is animated....Trey and Trinity finally got together dispelling any rumors about Trey and his tight pants! :D (Some of you will remember that topic)
Come on Cricky!
First, thanks for doing it!   It seems it was not a case of "deciphering" after all, because you made it and are giving it away!  Good!
I am a teacher Cricky! I am a 3D video production teacher, so I learned: To teach you must make learners, go step by step!   I bet, those who will "decipher" and try to make their OWN FADER will learn a lot much more, by "deciphering" my "Da Vinci" code than by downloading the FADER already done!
Of course, those who already know how to do it, might do better by taking your offer and getting it already done!    But...  It is so easy! really! It might take longer to download than to simply make it! (Paradox of Life!)
I agree the trick with the lights will do sort of the same, except you can not do layered dissolve as I propose.  Right?
Thank you for not leaving me alone in this.   It is good to be motivated as to explain better and to learn more!
Mike
By JimEH - 15 Years Ago
Thanks for the fade in sample. I will study this and hope to apply it to my projects. You are very talented.:)
By mausberg - 15 Years Ago
Another way to do it (IClone4)
- Goto stage and add a new empty layer
- Select a black diffuse map
- Set Opacity to 0%
- Go forward in timeline and set the layers opacity to 100%
- As the clip plays the screen will fade out
P.S: Of course you can use white or any other color for the layer, the content of screen will fade out to white, red ...
Another nice effect is to use a picture as diffuse bmp.
For example:
First you see a road with a car driving on it, as the layer fades in, the interior of the car
will be more and more visible, while the road and landscape is fading out ...
demo
By Apparition - 15 Years Ago
Good, mausberg!
Don't forget NOT all users moved to iClone 4 yet.
So please remember the "old fashion way" I showed is for all iClone users, including iC3 users.!
Mike
By tparrington - 13 Years Ago
Works great apparaition. Thanks for the step by step (I know this is an old post, but I'm a new user, lol). I agree that step by step instructions are the best way for people to learn how to use the complex system, and it's thrilling that there is always something new to learn or create.
