Dino trouble
https://forum.reallusion.com/Topic151618.aspx
Print Topic | Close Window
By tuttut_nut - 13 Years Ago
Having trouble moving dino's purchased from store. Keep getting error messages and I try to apply motions.
By W.VEEKE - 13 Years Ago
Hi, i think you put your motions in the wrong directory. You downloaded the dinos and also separate motions. You can appply this motions direct on the dinos just the same as you do with the Iclone standard characters. Please write me w.veek@home.nl
Ps: perform commandos only work if you put the motions in the correct directory
Or you use them direct
Wil Veeke
