iClone 4 pro Free, where´s my serial?
https://forum.reallusion.com/Topic145826.aspx
Print Topic | Close Window
By jay2013 - 12 Years Ago
So I downloaded iClone 4 pro Free (via 3dworld vault),
but can´t find the serial required to install. Created account here
but no serial to be found...
help appreciated!
By animagic - 12 Years Ago
Did you unzip tdw165-iclone.zip? It has a folder with the installer and a text file with the serial number (serial.txt).
for those with same difficulty:
problem solved, had to return to
http://www.reallusion.com/event/iclone4pro/3dworld.aspx
after registering and activating account.
(serial.txt doesn´t contain the serial, instead the above link) /thx anyway.
jay is actually right, it's my memory that's fading...:ermm:
By pjcurtis78 - 12 Years Ago
new to this and still cant cant find the serial number, if any one can make this simple i would thank them so much
pjcurtis78 (3/5/2013)
  • Assuming you are not an RL member, register first by clicking the red here link.
  • After you have registered, your serial number will be displayed.
Hope this helps.
By mrpetreli - 12 Years Ago
I can only fine iclone 5 pro, where is iclone 4 pro?. Please provide direct link
By Colonel_Klink - 12 Years Ago
As far as I know you need to own a copy of Issue 165 of 3D World Magazine and register the magazine at 3D World to access Iclone 4. Then register it on the page above.
mrpetreli (3/15/2013)
The link in my post is a direct link to the registration. As the Colonel points out, you need a copy of the magazine to get your free copy.
By grapeape1 - 12 Years Ago
It's really not too difficult ... promise!
1. Download iClone4 (I think I downloaded mine at http://minerva.3dtotal.com/iclone4/iClone4.zip)
2. If you have an account at Reallusion then go to http://www.reallusion.com/event/iclone4pro/3dtotal.aspx and login.
If you don't have an account, create one, then go to reallusion link and login.
3. You will then be taken to a page that contains YOUR Serial Number.
Whallah!
