By tonym - 14 Years Ago
I would like to be able to add moustaches, beards and stubble of varying lengths and colours.
By Peter (RL) - 14 Years Ago
Thanks for the suggestion. We will consider this for a future upgrade. :)
By SeanMac - 13 Years Ago
I also would like to add facial hair, shoulder-length hair etc Hair fashions are a main indicator of historical era, at least for males.
By SpaceCore - 11 Years Ago
For anyone who needs just a little more flexibility in hair styles and facial hair than even the Iclone Character Creator can give you;
Mixamo Fuse also has a character creator for free. It easy to create and export an obj of a nude character for each hair style, mustache style and beard style (nude because then you just have to create a quick character base for the hair to sit on)
Once you have the obj on your desktop, you can import it into 3Dxchange. Once in 3Dexchange, in the left hand column, deselect everything but the hair, mustache, or beard. Then "Align To Ground" in the right hand column, then back on the left hand column, click "Hide Excluded" then export to Iclone.
Now you have a decent hair prop that can be scaled and moved to fit, then parented to the head. I haven't tried this yet, but in theory, it seems you could parent the mustache to the top teeth and the beard to the bottom teeth and they should move with your avatars jaw when they talk. It isn't perfect, but it isn't bad at all and a very decent bandaid until Reallusion offers more/affordable hair options.
