Using voices I already own - to CrazyTalk Animator
https://forum.reallusion.com/Topic142402.aspx
Print Topic | Close Window
By SweetAngel - 14 Years Ago
Hi. I bought two character voices, and I was wondering if I could use those on Crazy talk Animator. If so, how?
Also, I have found this site:
http://www.nextup.com/
Would the english voices work on Crazy talk too?
Your response will be highly appreciated.
Thank you so so much♥
*SweetAngel*
By Peter (RL) - 14 Years Ago
When you use one of our products, including CrazyTalk, CrazyTalk Animator or iClone and select the TTS option to add a voice, the program will look to see which voices you have installed on your computer and make these available for use.
So all you need to do is install the voices once and all your Reallusion programs will automatically find them.
Can it be applied for voices from nextup.com too?
Thank you very much for the details and information :):)
SweetAngel (12/12/2012)
Nextup sell a variety of different voices from different companies. However as long as the voices are standard tts voices, they should work fine in CrazyTalk Animator.
By animagic - 14 Years Ago
Nextup has a limitation for some voices in that they can only be used in their own product TextAloud. So in that case you would enter the text in TextAloud and then record the speech to a file. You would then import this speech file in CTA.
