By toonarama - 14 Years Ago
Hello there I have downloaded all the bonus content but the base Auto Motion/Functional folder does not appear to have all the motions shown in the tutotial (there are only 15 in total). Am I missing something or has the bonus content changed. The other bonus content all seems to be present. Thank you
By Peter (RL) - 14 Years Ago
If you are referring to the Auto Animation Library Volume 1 pack, then you should find this in its own folder as shown below. If you don't have this folder, please install the pack again.
Peter I reinstlled but that folder is not there and the readme file does not mention it either as shown below (no mention of any auto motions) ===== Name: CrazyTalk7 Bonus Pack
Pack includes: 84 Motion Clips System Requirement =============== CrazyTlak 7.1 or above is required. Notice ===== If you want to backup your files, you might find it in the following path: C:\Documents and Settings\All Users\Documents\Reallusion\Template\CrazyTalk7 Template\Motion Clip\Facial Expression Clip Vol 1 C:\Documents and Settings\All Users\Documents\Reallusion\Template\CrazyTalk7 Template\Motion Clip\Natural Facial Performance Vol 1 The screenshot shows all that hs loaded up
I think we have a little confusion here over the type of content pack you are using. The Readme shows the pack you are referring to contains Facial Animation Clips Vol.1 and Natural Facial Performance Vol.1. These are not Auto Motions but Motion Clips. So just select the Motion Clip tab (under the Auto Motion tab) to view these two folders. :)
Peter Thanks for your reply (and sorry to be a pain) but I am afraid it is not there either.See screenshot below. Further investigtion shows that the additionl auto motion bonus content is not there either. I have the following 2 bonus packs in my account page: Crazytalk 7 (13.3 mb) and Christmas Bonus Pack (30.1 mb). The Crazytalk7 bonus pack appearing to include the motion clip packages Facial Expressions V1 and Natural Facial Performance V1 only
Peter I have a reply from support which indicates that the bonus content supplied with CT7 Pro is different to that which was originally available to the initial MAC users and that is why I am seeing a difference. They indicated that the online help and tutorials may be changed to reflect this and to avaiod further confusion Many thanks for your help Toonarama
By TonyTiger - 12 Years Ago
Hello,I have just recently purchased CT7 Pro also(01-30-14)and was HIGHLY disappointed with the limited content(PC VERSION),I installed the bonus content which is very limited-Again,highly disappointed with this software!!!!!!!!!-Refund????????
To top it all off,none of my CT6 Pro pack are compatible with CT7-Totally disappointed:(
By Peter (RL) - 12 Years Ago
TonyTiger (1/31/2014) Hello,I have just recently purchased CT7 Pro also(01-30-14)and was HIGHLY disappointed with the limited content(PC VERSION),I installed the bonus content which is very limited-Again,highly disappointed with this software!!!!!!!!!-Refund????????Can you please explain a little more about the lack of content? This is approximately the same as came included with CT6. CrazyTalk 7 comes with a variety of sample characters and projects. There are 16 projects, 13 characters and a variety of motion clips, voice clips and backgrounds. That's quite a lot to get started but of course most users will want to create their own characters. You also can access all your installed CrazyTalk 6 characters and scripts by using the Import function. Just choose File > Import Model or File > Import Script to bring them into CT7.
So sorry,my apologies!!!!-After playing around with this program and learning my way around a little bit I am in complete amazement!!!!!!This program ROCKS!!!!!!!! REALLUSION IS THE......Well you know:)))))-COMPLETELY HAPPY:))))))
By dcolson - 11 Years Ago
I can't install the facial expression bonus pack at all. On the install it errors out and says that crazy talk is not install on this computer.
By Peter (RL) - 11 Years Ago
dcolson (4/28/2015) I can't install the facial expression bonus pack at all. On the install it errors out and says that crazy talk is not install on this computer.
If you still have the problem, please try uninstalling CT7 and perform a clean install. You can download the latest version of CT7 from your Member Account.
If you still have problems after that, please contact Support using the link below. They will be able to help you with this.
http://www.reallusion.com/CustomerSupport/User/QForm.aspx
