Is it Possible to Import a Shockwave Flash Object (.swf)
https://forum.reallusion.com/Topic140765.aspx
Print Topic | Close Window
By brothertcoleman - 13 Years Ago
I tried importing a video but it only faces the camera ,I need it to be attached to an object and turn when the object turns not be facing forward toward the camera all the time.
Can I import a Shockwave Flash Object (.swf) in this way and it work for my purpose?
Thanks in advanced
By sjonesdc - 13 Years Ago
Have you tried to import the video into the Diffuse channel of a prop then attach it to the object???
Thanks,that worked .
By animatom - 13 Years Ago
I think you can't import .swf files.
About importing other graphics, maybe the most practical way is to drag graphic into a iClone main screen with right mouse button. That way, you will have option to choose how will this graphic be used; as a billboard, or image plane, or image layer, or texture (even in what slot; diffuse, opacity, bump, etc..)
Now only if the video had a transparent background it would be perfect,, that's why I mentioned swf because transparent background.
